Drain the coolant, then take that lower black pipe off and it sits right in there.
WHITECAVY wrote:It is in the thermostat housing on the back of the engine.. If you look from underneath the car, there is a black pipe coming from the housing. Drain the coolant, then take that lower black pipe off and it sits right in there. There are two little bolts that connect it to the housing. The other end connects to the lower radiator hose in the front of the engine.
Hope that helps.
Mark Sanders wrote:Thanks big help. Just an update 1 day after replacing thermostat the waterpump decided to have bladder control problems so now I get to replace it. This car is a pain in the a$$.
Brandon Schmidt wrote:Mark Sanders wrote:Thanks big help. Just an update 1 day after replacing thermostat the waterpump decided to have bladder control problems so now I get to replace it. This car is a pain in the a$$.
looks like your in for quite a wakeup call when u realize what is all involved in changing water pump on 2.4L
