Coil Pack Q&A - Third Generation Forum
Coil Pack Q&A
Thursday, February 02, 2006 5:05 PM
I took my coilpack housing off and its full of black dew of some sort .. i want to test them with an ohm metre but what am i looking for and how do i test them.. car wont start and im running outta ideas..
Re: Coil Pack Q&A
Thursday, February 02, 2006 5:40 PM
Black dew?
If its black residue, then you probably have a bad coil pack housing. They are called carbon trails, and its what happens when the spark from the coil pack goes through the housing instead of the plugs (or at least some portion of the spark).
Re: Coil Pack Q&A
Tuesday, February 07, 2006 5:58 PM
Got another coilpack question. i posted this in another forum, but need an answer fast. I was going to pollish the quad 4 cover, and had it off almost. had to go into work, and when I went to put it back on, I noticed that the white coils I guess were not locked into the rubber boots in the block. Car starts and runs fine, but is it safe, and if not, how do I reseat them? Thanks, Bob
Gotta keep on livin', L-I-V-I-N
Re: Coil Pack Q&A
Monday, February 13, 2006 1:46 AM
im guessing you mean that the boots are stuck to the head instead of the IDI cover? if so yes its ok to drive that is how mine are not only are they not attatched to the idi but they are a ^%&$ to pull off of the head! gotta grab em with needle nose pliers and hope you dont rip em.. so just leave them where they are and it should be fine/
Re: Coil Pack Q&A
Wednesday, February 15, 2006 9:43 AM
BluZR2, thanks for the info. You have it right, and they are a s.o.b. to get off the head. Car is running fine the way it is now, I guess no harm done.
