Theft light on ? - Third Generation Forum
Theft light on ?
Tuesday, June 28, 2005 7:03 PM
My 2000 chevy cavi's theft and service light is on . When I pulled up the code was for the theft kill to full pump and cant remember the other . Is there any way to deactivate the theft system in the car ? Any help would be appreciated .
Re: Theft light on ?
Wednesday, June 29, 2005 9:22 PM
disconnect battery/reconnect it?
Wednesday, June 29, 2005 10:37 PM
Has to be done through a Tech 2.
Thursday, June 30, 2005 7:57 AM
David Rubal wrote:My 2000 chevy cavi's theft and service light is on . When I pulled up the code was for the theft kill to full pump and cant remember the other . Is there any way to deactivate the theft system in the car ? Any help would be appreciated .
Ummmm, I think you broke it.
Thursday, June 30, 2005 12:49 PM
i had the same problem w/ my car. when i swapped clusters the car would start, then die and the theft light came on. what i was turn the car on and let it die. LEAVE the key in the ignition but turn it one click back so its on the on position. dont turn anything on or open the doors or anything. the theft light will flash and then just stay on. sit there for about 10 mins and you'll hear the computer fixing itself. once that noise goes away wait for a min, turn the key to the off position but dont take it out. leave it there for 15 secs and then start the car. worked perfectly for me.
Thursday, June 30, 2005 12:57 PM
Passlock is slightly different between 98 and 2000 models, though. You're re-learning the R-code with that procedure. Can be done on the 2000 like that, but it has to be repeated three times for it to work.
<a href="http://www.lenkorules.com/"><img src="http://s93165229.onlinehome.us/images/zm/sig/LRDCsig3.jpg"></a>
Thursday, June 30, 2005 1:03 PM
hmmm.... ok i thought it might be different. i remember reading a post about how to do it and the guy said it may take 3 times for it to work.
Thursday, June 30, 2005 4:58 PM
[quote=ßãggéÐÇåv98 (Ûñqùðtäߣè Øñé)]i had the same problem w/ my car. when i swapped clusters the car would start, then die and the theft light came on. what i was turn the car on and let it die. LEAVE the key in the ignition but turn it one click back so its on the on position. dont turn anything on or open the doors or anything. the theft light will flash and then just stay on. sit there for about 10 mins and you'll hear the computer fixing itself. once that noise goes away wait for a min, turn the key to the off position but dont take it out. leave it there for 15 secs and then start the car. worked perfectly for me.
That only works on the 99-'s, the 00+'s have a different type of theftlock.
