tokico springs? - Suspension and Brake Forum
tokico springs?
Wednesday, November 09, 2005 2:50 PM
i never heard of tokico making springs? everyone talks about the d spec struts but not about the springs. anyone have any experience with these?
http://cgi.ebay.com/ebaymotors/TOKICO-DSPEC-SHOCKS-SPRINGS-CAVALIER-SUNFIRE-95-04_W0QQcmdZViewItemQQcategoryZ33590QQitemZ8012768527QQrdZ1QQsspagenameZWDVW
Re: tokico springs?
Wednesday, November 09, 2005 4:53 PM
They should be of good quality. Its rated at a 1.6" drop, which is well within the D-spec operating range.
Re: tokico springs?
Wednesday, November 09, 2005 5:03 PM
Yeah. They're good stuff. I'd put them up there with H-R or B+G, Goldlines, and others like that.
Re: tokico springs?
Wednesday, November 09, 2005 5:09 PM
I have that kit, and they're definitely worth the money. Esay install and easy adjustment.
Re: tokico springs?
Wednesday, November 09, 2005 7:31 PM
zach, is yours a 1.6 drop on both front and rear?
Re: tokico springs?
Friday, November 11, 2005 4:00 AM
I just installed the Tokico Suspension System inlcluding the D-Specs and springs and even I can't compare with other good brands I love them. Ride goes from stiff to soft in seconds. The Tokico springs are proggresive and they are doing a good job. The system is rated for 1.4" drop but I just get 1" for now being installed two weeks ago. Don't know if they will settle lower by the time but let see what happens. Hope this helps.
Re: tokico springs?
Friday, November 11, 2005 5:09 PM
^^^Actually its 1.6". Mine sat a little higher for a few days until they were completely settled. Are you sure you only got a 1" drop? I took exact measurments before and after the install, and I had exactly a 1 5/8" drop. Also, I know what you mean, the progressive springs do an excellent job, but can be a wee bit stiff at times.
Re: tokico springs?
Wednesday, November 16, 2005 4:36 AM
Yes, just 1" for now. I do have the before measurements and still the same. I haven't run the car enough so let see if when I add miles to it, it goes lower or not.
Re: tokico springs?
Wednesday, November 16, 2005 5:33 AM
V Dub wrote:zach, is yours a 1.6 drop on both front and rear?
H&R is rated at a 1.6/1.4 drop, but I never took the time to measure it. Here's a pic:
