Question regarding air leak - Suspension and Brake Forum
Friday, November 04, 2005 6:16 AM
OK here what's being going on i have install the easystreet kit let me tell you the kit is amazing but i have a leak some where, i would leave the car up at 100psi at night and by morning the passenger side is all the way down. I know people have used soup and water to find it, just checking to see if there is any other way to find the leak and i can barely hear the leak some where.
Re: Question regarding air leak
Friday, November 04, 2005 6:22 AM
alright lets start with this?
1) is it the whole passenger side or just one corner of the passenger side?
2) are you positive the leak is coming from the tank area (where all the vavles and fittings are).
3) before you spray it down with water, check the fitting where the tube goes into the line lock. i dont know if your using the 90 degree elbow or the straight fitting but i had a problem w/ mine where i had a leak. i unplugged the line to look around and found that the little metal cylinder that is in the line lock fitting was stuck in the line (basically the fitting was broke)
Friday, November 04, 2005 7:36 AM
yes it the whole passenger side and i'm using the 90 degree elbow, i'll look into that baggedcav98 to see if it broke and thanks for the help
Friday, November 04, 2005 7:37 AM
well if its the whole side, i doubt it is the fitting. just do what you said and get some soapy water and spray all the fittings for that side of the car. also you may want to take apart the valve and see if there is anything in there causing it to stick.
Friday, November 04, 2005 2:20 PM
^^^ Man, you should be getting paid for all your tech support lol
www.TaillightTinting.com #1 SOURCE FOR VHT NITE SHADES
www.aPlusPerformance.com BACK ONLINE SOMETIME SOON!
PHONE 763-682-9945
Friday, November 04, 2005 3:07 PM
lol work was so slow today so i posted on the org for 8 hours
Friday, November 04, 2005 6:34 PM
so in other words, basically you were getting paid for your tech support haha
Saturday, November 05, 2005 9:23 AM
basically yea, although dont tell work that
