At low speeds and when coming to a stop i hear a slight popping nose i've already changed the strut mounts all the way around because it was clunking and such, i've only got 12,000 miles on the car i'm lowerd on KYB AGX and the Eibach Prokit, what could be causing this popping noise? Thank you.
i have stock suspension and mine does it. maybe its common on cavaliers
mine does it and if its the same thing it's a brake problem, the rear drum ovalize over time (well in 2 months mine ovalized) and make the pads stick onto the caliper surface mostly on the driver side!
Take it to a dealer, you're still under warranty. ProKit and KYBs will not void the warrant (except on those items). Sounds like the CV joint though.
