First off, i have Bomex front and sides (urethane) and a drift rear (FG)! I measured and from the ground to the front is about 6 inches, and side skirst about 5.5 and the rear is 7-7.5 around there. Now i know these Suspension Tech only lowers about 1.2" all around, but just wondering if anyone has any comments on them? The only area i'm concerned about is the drift rear, but it's 7" from the ground behind the tire.
What struts would be good with these? KYB or Koni Yellows?
It's probably either going to be these or the Pro-Kit. Just want some ppl's comments. Thanks guyz
they are gooooooood! its true! its true!
but seriously...good choice. you can run em with any strut really... its not that low of a drop, but agx will be more than enough for em and give you some tuning adjustability.
Okey here is a somewhat good pic of my car. You can see the front and sides.
Think that is too low of a drop, and do u think the Pro-Kit would be better?
spud_51 wrote:Okey here is a somewhat good pic of my car. You can see the front and sides.
<img src="http://www.angelfire.com/md/TOWSONFTBLPLYR/redX.gif">
pics not working as of 11:12pm easter time...
yeah you should be cool. pro kit is even lower...
thing is, you gotta factor in for larger bumps and such, especially with a fiberglass kit.
Yeah i know about the FG, but it's only the rear, but still have to watch for bigger bumps, and what not.
Event- would u stick with the Suspension Tech or go Pro-Kit?
honestly, at that point it;d be a skippy or jif choice...
if i were you (theres not much difference) but meausre how much space you have from flat ground to the lowest parts of your kit.... if you can splurge for the 1.4 go for it... if you measure and have a really close setup to the ground now, stay conservative and go with the 1.2...
also if you dont have much to spare, check out the Tein H-Techs... not the S -techs...
By any chance would anyone have a pic of a J with the Suspension Technique springs?
ThanXs in advance.
>>>For Sale? Clicky!<<<
