Ok i got my washers from kyb for my agx's... i noticed 2 things. One they are heavy as all heck. But most of all they are super thick! Is there really a need for them to be so thick? Scares me to think that theres that much space to take up? Anyways, hoping to put them in in a couple days. Going to try removing the nut without taking them off the car. Try not to move anything and spare myself buying another alignment even tho i probably should. The car will hold itself down on the springs and everything right? without the nut?
98' Pontiac Sunfire SE
It spring will probably kick....just go slow
Hey Jared. I've taken that nut off a few times while the strut was still on the car. I never had any problems. I'm lovin' my Tokico D-Spec suspension now that i've got all the bugs worked out. Good luck.
thats the answer i needed
Funny, cause I got the AGX and I got to a machine shop to get two spacers/washers and it's pretty similar to that. Guess I won't have problem with that....
nice stuff then... they came in a couple days, response was fast
so why do we need the washers again ?
because on the original mount, there was a nut with a spacer (same piece), but with the AGX you only have a normal nut...
really >? ? uh oh ... isa this the reason why sometimes i hear a poping sound comming from the front ?
