changing struts - Suspension and Brake Forum
changing struts
Saturday, July 23, 2005 3:08 PM
on a 01 cavalier will i need anything else to put aftermarket struts on my car besides what comes in the box? of course i know ill need tools. please dont post that.
"IF YOU PERSIST IN DOING WHAT YOU HAVE ALWAYS DONE .....
EXPECT RESULTS NO DIFFERENT FROM WHAT YOU HAVE ALREADY ACHIEVED"
Re: changing struts
Saturday, July 23, 2005 3:57 PM
what struts ?
If they are OEM style replacements then you shouldn't need anything else.
Re: changing struts
Saturday, July 23, 2005 4:08 PM
I just helped a friend drop his Civic (similar procedure), and auto parts stores have a little kit full of washers and bushings that come in handy. We actually had to use a dremel to cut a few bolts (they were rusted on and we were lazy), but I don't think that will be a problem. Other than that, you won't really need anything else.
Re: changing struts
Saturday, July 23, 2005 4:23 PM
keep the dremmel away from your car
you can take everything off and put it back on with hand tools if you don't have air tools.
breaker bar
socket set
torque wrench
maybe some WD40
spring compressor (just rent it at the auto store)
and a hammer to tap out the front steering knuckle bolts.
however I do recommend using an impact wrench if you can borrow one. it will make getting the top nuts off allot easier.
Re: changing struts
Saturday, July 23, 2005 5:01 PM
the struts im thinking about are the kyb agx's if that helps. sorry i didnt add that.
Re: changing struts
Saturday, July 23, 2005 5:12 PM
With the AGX set up you MAY need some washers, but as I understand KYB includes them in the box now, nothing major. look for the bradiscool.com there is a spring install there. i will get you through nicely.
Re: changing struts
Saturday, July 23, 2005 5:14 PM
thanks for the help guys.
