Over Steer....Understeer.....Im so damn confused - Suspension and Brake Forum
Friday, June 03, 2005 12:07 PM
K i want a sway bar and everyone keeps talking about understeer and over steer...can someone explain them to me please?
Re: Over Steer....Understeer.....Im so damn confus
Friday, June 03, 2005 12:37 PM
Here is a link to read http://www.progressauto.com/pages/oversteer.htm
Here are corrections for understeer/oversteer. Sway bars are discussed about 1/3 of the way down http://rogerkrausracing.com/overundr.html
Friday, June 03, 2005 1:06 PM
understeer would be when your barreling into a corner and you point the nose one way and it goes the opposite way your pointing in nascar terms this would be a tight condition
oversteer would be when you go barreling into that same corner and your front end points where you want it to but your back end slides out to the opposite direction almost like how someone drifts a corner in nascar terms this would be a loose condition
Friday, June 03, 2005 1:25 PM
download this... its an interactive demo from Nitto
http://nittotire.com/Interactive_%20Demo.exe
Friday, June 03, 2005 4:07 PM
Awsome thanks alot
Friday, June 03, 2005 4:21 PM
I like to think about understeer in terms of terminal understeer (this is how you know you got it). If you go into a corner too hot and you have the wheel turned all the way to the left or right the car will break traction in the front and start sliding straight.
Oversteer at the extreme is when the car wants to spin out on you.
Sunday, June 05, 2005 1:48 PM
oversteer is when the front has more grip than the rear causing the ass to slide out,understeer is when you loose most traction in the front resulting in the assend trying to push the car streight
