im going to be installing my koni yellows & eibach sportlines when they show up in the next few weeks and i want to make sure i got all my bases covered so i dont run into any surprises..
my question is am i going to be having any issues after i lower the car?
i will be installing:
koni yellows
eibach sportlines
oem front sway bar
95-99 bearing plates
i have 18" motegi mr-8s & nankang 225/40/18 rubber
also i will be getting a subrame brace from ken 2.2 soon
thanks in advance!
btw. heres a pic of the 4x4 gap i got goin on now.. lol if it helps
My car was made with wrenches, Not chopsticks.
btw. if i will be having any clearance issues i also have set of intrax springs to that i could use in place of the sportlines... if that helps
u shouldnt as long as your wheels are the right offset...
good ! thats what i wanted to hear
thanks
well just to sum it up, since you got the right tire size, 225/40/18, you have the same stock rolling diameter as if you had stock wheels and tires.
lowering it can really only hurt you if your offset is something wild like something that makes the tires overhang REALLY bad.
just hit up a reg alignment and your set
I have only scraped my SFB once and that was today, not damage to the car but it sure did sound bad. I was actually hard pressed to find the scrape. and your going to be lower than me. just keep in mind you can't off-road anymore.
thanks everyone for the info!
