would simple $20 brake pads work with slotted rotors?
hugs and hand pounds, peace
So your willing to spend lots of money on slotted rotors, but when it comes to pads, the most important part of your brakes, your going to cheap out? The cheap pads will work fine, but your logic seems kinda faulty to me.
Pat(stopitbrakes) has a GP going on right now. Tell him you need a good set of pads. They will probably run you about 30-40 and they won't let you down.
they will work, but i think they will wear out faster.
i have the Ti22 pads from Highrev. i think they are good
Zach wrote:Pat(stopitbrakes) has a GP going on right now. Tell him you need a good set of pads. They will probably run you about 30-40 and they won't let you down.
GP is over
<A HREF="http://www.cardomain.com/id/eazy716"><IMG SRC="http://registry.gmenthusiast.com/images/eazy716/personal_pic.gif" BORDER="0"></A>
No they won't. If you want cheap but effective pads, go with Axxis.
REAL MEN BATTLE DOWNHILL!!!
i went to Advanced Auto today and got Bendix semi-metallic pads.thay were $48. that was the best they had.
also i believe that with the bendix pads u get a free pair after ur 1st pair wears out
