Ridin on GC/Koni with a 19mm Hellwig rear sway bar/GRD Tie bar. I've been told that without a front swaybar, the rear end is gonna be so tight that I will be able to literally drift and the back will swing out when I don't want it to.
Whats a good match for this combo?
BTW, the sway bar/tie bar still isnt on. I want to verify this claim first.
Vice President - NEJBody
2007 Cobalt SS
2001 Sunfire (retired)
Just pull whatever OEM front bar off a stock J that you can. Those range from 18-22mm I believe. Whatever you end up with, you can compensate with in tire pressues and shock stiffness.
On a side note, I had a tie bar installed on my car and took it off because I felt it added entirely too much oversteer.
you can get any front bar you want, if you get an 03+ they had a 24mm bar on them, and the bar is cheap from GM, you can look it up on www.gmpartsdirect.com
Mike
1992 GMC Sonoma GT #492. Oh, Its just a stock V6!
1999 Cavalier Coupe, daily driver, 2200/M5. Mods and pics are in my registry.
Fully built turbo 2200 in progress, should be installed very soon. Will post details as they happen.
Support the site that supports your habit, Go Premium.
Im premium since January, but why doesnt it say that?????
pjk91 wrote:Ridin on GC/Koni with a 19mm Hellwig rear sway bar/GRD Tie bar. I've been told that without a front swaybar, the rear end is gonna be so tight that I will be able to literally drift and the back will swing out when I don't want it to.
what do you do with your car? if you autox then i would say 18mmbar to still have a neutral car, that would not push so bad. but if not then for safety i would go 03-up 24mm. and have you looked into control arm bushings? he// may as well slap them in while you have the sub-frame down
see ya!
I'll probably go with a 24mm from the 03+. I don't do any autocross but I LOVE driving it hard its just so fun hehe. but i might do some autocross this year, we'll see.
2007 Cobalt SS
Here is my setup, do you guys think i will have problems? H&R 1.6/1.4 lowering springs, kyb gr2 struts, gravanas front and rear strut bar set, rear sway bar, and im thinking of getting front sub frame connector, will i have problems like pj is thinking of possibly having, of the rear end being so stiff it will slide out?
Sorry to post-jack .... but does anyone make a rear tie bar that'll work with the rksport rear sway bar?
ive got the 1" hellwig sway on the rear , and i have yet to have the car try to come around on me
ive got the stock 18mm front bar , and if i ever quit being lazy ill get my front 1" bar put on both of my cavs
lol
You ever try autocrossing eric? I have the 18mm up front and a 25.4mm in the rear (addco). I can get it to come around, but no where near as easily as I could with a tie bar. IMO, the swaybar setup I have now is perfect. I have just a touch of oversteer, but not enough to get into any trouble.
Carbon Cavi wrote:Here is my setup, do you guys think i will have problems? H&R 1.6/1.4 lowering springs, kyb gr2 struts, gravanas front and rear strut bar set, rear sway bar, and im thinking of getting front sub frame connector, will i have problems like pj is thinking of possibly having, of the rear end being so stiff it will slide out?
You will if you don't stiffen the front up with a sway bar. The sub frame brace had minimal effects in my opinion.
How did you get the Helwig 1" rear?
Been looking for that bar for a while.
And with my recent raise I should actually be able to afford it now.
Selling or know where I can get one. (or you and I pay+the finders fee)
Or,
pjk: are you willing to sell your Helwig rear bar?
When I had the 25.4mm rear (eibach/addco) and tie bar combo I could get the end to kick around of sorts.
My car was always FE2 suspension. And I had the front SFB, poly a-arm bushings, and f/r strut bars to compliment everything.
With the RK 22mm rear, there was still ever so slight understeer
Grrr
Mastin, if you have a different sway bar right now I may be willing to trade with you. I have a Hellwig with reconditioned hardware (sandblasted and powder coated the brackets and have new J bolts).
I dont have any rear bar right now.
But I wanted to check out/get a feel on the Helwig rear.
I mean, Ive been noticing in general cars have smaller rear sway bars.
Most likely for normal driver safety.
But even the high end gtps only have 19mm rears from the factory.,
I was like
And Event liked the feel of the Helwig so I'd like to try it out too.
If you needed me to foot the bill for another bar for you I could do that.
And trade for the Helwig that way.
-M
MasSnead2@aol.com
is it hard to add a front sway bar to a car that didnt come with one? honestly i havent looked under the front of mine yet to tell if i have one or not. i have a 00 2.2. if it came with one i heard its easy to swap, but if it didnt....? how hard and long of a project are we talking there?
There is a post about putting the front bar in with many pictures. It will take you a few hours.
This is actually Art's rear bar/tie bar. He sent it to me with all new hardware and the such. I'm going to put it on and if I don't like the stiffness I'll send you an email
2007 Cobalt SS
OOooo I remember,
I came over like the next day to buy it and he said he just mailed it out.
LOL
All good.
-M
Yeah I have the RK 22mm rear bar, and it is about neutral for me...a little tight yet, but not much. I have the 18mm front from the factory on my 99z.
I would like a 25.4mm one...but I don't feel like buying one when I already have one.
-da chinchilla
<img src="http://registry.gmenthusiast.com/images/jiggamon/avatar15569_2.gif">
