Rear axle bushings - Suspension and Brake Forum
Rear axle bushings
Saturday, March 17, 2018 10:39 AM
Trying to press out rear axle bushings . Dead axle is to heavy to support when using a standing press and a ball joint press isn�t big enough when using the c clamp style press. Suggestions ?
Re: Rear axle bushings
Saturday, March 17, 2018 1:05 PM
I had to burn mine out and cut the metal sleeve out.
Sunday, March 18, 2018 4:07 AM
I bought the Kent Moore tool for trailing link bushing removal and installation. Well worth it. Makes the job a real breeze.
You can see it in this thread;
http://www.v6z24.com/jbodyforum/full-bushings-replacement-t135457.html
Not sure if this is the same tool used on a 3rd gen or not. If not, I'm sure there is a correct one for your application.
