Need Help installing KYB front strut mounts! - Suspension and Brake Forum
Monday, August 10, 2015 5:46 PM
As the title says, I need some help. I'm trying to install kyb agx struts with moog variable rate springs, and kyb mounts (part #SM5142). I can't for the life of me figure out how these mounts are supposed to work.... There is the main part of the mount that bolts to the body, then there is a flat shim, a clockable angle shim, and a bearing plate, all of which are smaller than the inside diameter of the springs... What gives? Are these the wrong mounts? Do I need to order the ones that look like stock?
Re: Need Help installing KYB front strut mounts!
Tuesday, August 11, 2015 8:21 PM
Has anyone used this part number? They are one piece, instead of the factory 2 pieces. Are these mounts perhaps for a newer cavi(02+)?
