Since im redoing my entire suspension setup im going to have to get it aligned.
Since im buying new coilovers I will not slot the holes out in the bottom. So the options I can think of are camber bolts and the adjusting of the camber plates.
So what is the approved way? I read that adjusting by camber plates will change things in terms of contact patch? I dont mind buying a set of camber bolts if it means not grinding my new coilovers.
As for settings I was going to go -1.5* of camber and -1* toe in
1 degree of camber is 1 degree of camber no matter where you get it. Use the camber plates. Thats what you got them for haha.
I was able to dial mine in on the alignment rack with the camber plates. I took notes ( have no idea where they are now ) on have far I could go on both positive and negative camber. I will do it again with the STD R5's when the car is running
Jason
99 Z24
LG0/LD9 for Life
10 Year Bash Veteren
The coilovers im getting has camber plates.
I was just concerned because I was reading and people were saying you shouldn't use your camber plates to get your desired camber. Which honestly didn't make one bit of sense.
Philly D wrote:The coilovers im getting has camber plates.
They are correct. Camber plates are designed for quick, at-the-track changes to camber, not for setting the initial angle. That's why they have notches and marks, etc, so you can get repeatable changes whenever you adjust it.
