okay guys. i have an 04 sedan.
i am looking for what size hubs to get it flush without the gap.
just got my eibach sportlines and about to order my koni yellows.
i have stock 16' WRX alloy rims.
so what size hubs?
thanks all
![](http://i74.photobucket.com/albums/i255/crazy_filipino22/IMG00216-20110213-15121-2.jpg)
Little Sedan That Could <3 Forever
Two things. Offset of rims need to be known. Second is the widths.
I don't recall the offset of the rims.
be prepared to also space oneside out 1-5mm extra vs the other side. the rear axle is never 100% centered.
16x6.5 alloy, offset 55 (2.17), bolt pattern 5-100
azncav wrote:Two things. Offset of rims need to be known. Second is the widths.
here you go 16x6.5 alloy, offset 55 (2.17), bolt pattern 5-100
DaFlyinSkwirl (Pj) v2.0 wrote:be prepared to also space oneside out 1-5mm extra vs the other side. the rear axle is never 100% centered.
so what would need to be done?
go get you some 1" bolt on spacers like these
click here!. i would try to find some hub centric ones though. 1" is about 24-25mm so that would bring your wheel offset down to about 30 or so. if you want an idea to where that will bring you take a measuring tape and measure you 30mm from you wheels lip.
azncav wrote:correct 5x100 to 5x100 spacers using these will keep you from having to extend your stock studs
so these over the previous ones?
