i have been having some trouble with my suspension i wonder if its because i need new shocks or what. My suspension shifts from side to side when i shift or when im turning and idk y, i have it dropped on tein s springs have the control arm bushings and regular stock shocks. I do not know if its probably time for me to get new shocks or what. I have done my alignment and it still keeps on doing it. Hopefuly someone could give me a lead to what it might be. Thanx
Ernie
erniscavi wrote:i have been having some trouble with my suspension i wonder if its because i need new shocks or what. My suspension shifts from side to side when i shift or when im turning and idk y, i have it dropped on tein s springs have the control arm bushings and regular stock shocks. I do not know if its probably time for me to get new shocks or what. I have done my alignment and it still keeps on doing it. Hopefuly someone could give me a lead to what it might be. Thanx
Ernie
well, since you SHOULD have gotten dampers to handle the drop in the first place, congratulations, you did it wrong, and now need to do the alignment again after getting either some d-specs or yellows.
this, kids, is why we don't drop on stock dampers.
stock shocks or not thats not going to make thing move like hes talking. Harsh ride, yes, parts shifting, no.
Spencer wrote:stock shocks or not thats not going to make thing move like hes talking. Harsh ride, yes, parts shifting, no.
if the dampers don't dampen, the car will lurch turning a corner. weight shift will happen as well while shifting. putting the proper dampers on it, at the very least, will help in further diagnosis.
Could also be rear trailing ARM bushings allowing the ass end to shift side to side.
Instead of doing it right the first time, now you can do it right the second time!
________________________________________.
Still not low enough for a signature.
check for a broken bolt in the front bushing of the control arms, also make sure they are torqued properly. I had this issue and all i had to do was torque to spec, no more pull and clunk. But got thu all the bushing and check them just for good measure.
