After replacing the strut assemblies on our '03 Cavalier with Monroe QuickStruts a some time ago, I did a quick camber adjustment with an angle finder on the hub and called it good. Today I finally put my nice new(ish) FasTrax camber/cater gauge on the car and am in the (annoying and laborious) process of setting the camber to zero. After that I'll check the caster, but if I don't like the results, I don't see any way to adjust it! The only suspension adjustments I see are the slotted bolt hole in the replacement struts, and of course the tie rod sleeves - so I'm left to *assume* that the caster isn't meant to be adjustable from the factory?
_________________________________________________________________________________
2003 Cavalier, base with auto/tilt/CD/AC (wife's) -- 2012 Mazda5 Touring with audio package (mine)
to adjust caster you either move the tops of the struts forwards or backwards or move the sub frame forwards or backwards (which moves the lower control arms forwards or backwards). Hardly no one ever adjusts it though.
Sponsored by:
Kronos Performance
There isn't too much caster adjust-ability in the J platform, and what there is for adjustment isn't even recommended by the factory. Leafy nailed it.
My question is- why would you adjust camber, then caster? You should adjust caster first, since the camber changes when you change caster.
There's only 2 reasons I can see to adjust caster. The car was wrecked and now the caster is all over the place. Or if you are a serious racer who competes at least that the regional level, if not nationally.
Sponsored by:
Kronos Performance
