Rear strut bolt size - Suspension and Brake Forum
Monday, October 17, 2011 5:34 AM
I have to get a wrench or socket to remove my rear struts and dont know the size.
What is the size of the lower bolt that connects the strut to the trailing arm?
Re: Rear strut bolt size
Monday, October 17, 2011 6:00 AM
I THINK 19mm? I don't remember off the top of my head
Monday, October 17, 2011 6:05 AM
18mm.
Monday, October 17, 2011 8:17 AM
Think 18 is correct. Better suited to get a full set of 1/2 drive sockets so you have everything u need
Monday, October 17, 2011 8:32 AM
Poo, I was close.
Go down to harbor freight and grab the large set of Pittsburgh deep well sockets. I use them all over my car, never had an issue
Monday, October 17, 2011 12:52 PM
Odd I tried a 18 and 19 and they didnt fit the bolt head.
Maybe time to retry it.
Monday, October 17, 2011 4:22 PM
yup its 18mm
Monday, October 17, 2011 4:28 PM
Philly D wrote:Odd I tried a 18 and 19 and they didnt fit the bolt head.
rust or dirt on the hardware.
1999 - Cavalier - 5speed - Exhaust - 17" rims - carbon fiber hood - the beater
Monday, October 17, 2011 8:19 PM
Isnt the bolt head and nut a different size? I swear I ran into that when I installed my sway bar, and then the hardware that came with the swaybar had yet another size bolt, but the bolt and nut were the same size.
Sponsored by: Kronos Performance
Monday, October 17, 2011 8:34 PM
Not sure about the nut, I think its the same size. Other than that nut, I have every other bolt size memorized to pull the rear struts.
Tuesday, October 18, 2011 11:05 AM
Leafy (Club Jeffie FEA man) wrote:Isnt the bolt head and nut a different size? I swear I ran into that when I installed my sway bar, and then the hardware that came with the swaybar had yet another size bolt, but the bolt and nut were the same size.
Yes...!
I am taking off my eibach rear sway and putting it on my new cav. There is no way it's 18mm.
Do you recall the size? Maybe my other socket set has the size I need. Didn't think of that till now
Tuesday, October 18, 2011 4:25 PM
its 18mm or if anything the biggest would be 19. the nut is welded on.
Tuesday, October 18, 2011 6:11 PM
False My nut was not welded on and my sway bar kit came with a new one.
