ok so today i went to take the bolt out that holds the bottom of the strut to the rear axle and i couldnt get it to come out. After some investigation i found that the metal tube that is in the middle of the bushings on the bottom of the agx's has attached itself to the bolt not allowing the bolt to come out. I should also mention that the bolt i was using was the bolt form the eibach sway bar kit, not the stock bolt. I am just curious if anyone else has run into this problem and if they have what the remedy is.
Any insight would be much appreciated because i am at a loss here as to how to fix this.
Heat+PB Blaster in copious amounts.
ya i let it sit with a goodcoating of pb blaster all night. im worried with the heat though that i will melt the bushing, isnt this true?
