I have had a problem with my Cav pulling to the right when braking after failing to avoid something in the road. A part is dented under the car by the wheel, and I believe it to be the Front Driver Side CV Axle. Does this problem sound familiar to anyone? I will post pics shortly, please respond.
Atlanta Region SCCA
28 ST
BatlGround Motorsports
usually a pull when braking is a bad/sticking caliper or brake hose, if you had a bent axle, youd have hella vibration.
i would say you have a caliper goin bad
in my experiance that is if it was a bad shaft you would get it while driving
JBO since July 30, 2001
