Here's a pretty cool video that will show you how to replace the front disk brakes on your Sunfire
nice to have but if you need that to change them then you shouldn't work on your car cavalier discs are the easiest car to change the brakes
JBO since July 30, 2001
And if you have an LN2 the brakes are easier than changing the oil. Haha
I accidentally the SHIFT LIGHT!!!!!!!!!!
The proper way of using the word seen. It is not I seen it that would be I saw it. He has seen the car is the right way to use the word. English class is Cool. By the way thats my sig
Wow, amazing how he has been working on cars for 20 years and left out the fact that you should lube the allen bolts with caliper grease.
and if you have a wheel like my old ADrs with enough reach around space. you dont even need to jack or remove your wheels to do the
brakes.
azncav wrote:and if you have a wheel like my old ADrs with enough reach around space. you dont even need to jack or remove your wheels to do the
brakes.
Then how do you replace the rotor???
NOTa2_4 wrote:nice to have but if you need that to change them then you shouldn't work on your car cavalier discs are the easiest car to change the brakes
I was thinking this should be in either the Newbies Forum or Maintenance Forum.
dude, to replace the rotor, take the wheel off and 2 hex head bolts on the caliper, and the rotor comes right off. sooo simple
"A goal without a plan is just a wish"
im pretty sure he knows how to change his rotor lol he ment how do you change it with the rim still on the car
