Lol at the title..... But really I have awesome front steering and cornering but even though the front handles good I have a huge problem with the back end getting loose under heavy cornering at higher speeds. It kinda scares the crap out of me. I want to be able to corner faster and I have 235/45/17 tires in the back so they are plenty wide enough. Is there such things as a independent rear suspension conversion or would a rear strut tower brace help with this issue much? Sorry If these are already asked questions, I just wouldn't know what to search for in this section.
IRS swap
Strut brace would help, anti-sway bar would help. Tie bar helps more in shifting lane type movements I found. Higher spring rate in the back is good to have too.
it's a sticky at the top of the suspension forum that you posted in. seriously now.
With the IRS you can get disk brakes too! I got my setup from the junkyard for $100. Don't forget you will need to change your exhaust too.
Sig'less since '02!
did not even put the two together never even hit that (IRS) was independent rear suspension... derp
bradsk88 wrote:Higher spring rate in the back is good to have too.
No, that would make the problem worse in this situation.
A bigger front bar, higher front tire pressure, and lower rear tire pressure would help.
Stiffen up the front end more will
Make it more neutral.
nothing to contribute, but best thread name evar lol
Congratulation, you're the only one. Whats your setup so I can copy it, I want oversteer, this whole understeer business is lame.
Unless its getting loose only on single wheel bumps...
Oh @!#$, those wide sticky tires in the back might actually be causing enough toe change in the rear to make a difference. Triangulating the rear trailing arms would help you out I suspect. Theres only one properly done setup that I know of and thats this one. The top 2 blue bars are the ones you want.
Sponsored by:
Kronos Performance
where do those two top bars connect on each side?
horsepower is the force that determines at what speed you hit the wall, torque is the force that determines how far you take the wall with you after you hit it.
James Cahill wrote:bradsk88 wrote:Higher spring rate in the back is good to have too.
-MD- Enforcer wrote:Stiffen up the front end more will
Read these two, there's your answer.
>>>For Sale? Clicky!<<<
02 silver cavy wrote:where do those two top bars connect on each side?
The tops of the trailing arms. I'm going to guess the top of the bolt that is for the swaybar or a hole drilled in the trailing arm.
Sponsored by:
Kronos Performance
it looks like they go up to where the wheel bearing bolts would be, in that general area correct?
On the top of the trailing arm at the back of it. i dont think it gets more descriptive than that.
Sponsored by:
Kronos Performance
