Rock hard front sway bar link bushings - Suspension and Brake Forum
Monday, December 06, 2010 6:46 PM
Are the stock front sway bar end link bushings white and rock hard? Mine are, they feel kind like delrin and look like it as well. I would have figured that they would just be black soft rubber like normal.
Sponsored by: Kronos Performance
Re: Rock hard front sway bar link bushings
Monday, December 06, 2010 7:16 PM
To my knowledge, the stockers are soft black rubber (like every other sh!tty bushing on our cars). Mine are at least.
Monday, December 06, 2010 7:18 PM
hmmm. This is interesting. I'll venture outside with a flash light and get a picture.
well they're not white but look like they used to be. They're definitely rock hard.
Edited 1 time(s). Last edited Monday, December 06, 2010 7:25 PM
Monday, December 06, 2010 7:34 PM
Mine use to be white, but were replaced at one time, but I plan to replace again.
Monday, December 06, 2010 7:41 PM
Also, whoa that picture makes my lca's look not even close to parallel to the ground.
Monday, December 06, 2010 8:13 PM
yup both my 97 and 98 had those same bushings. more yellow than white though....
If it takes forever.... I will die trying. Underdog Racing
Monday, December 06, 2010 8:17 PM
I have the same bushings as well...but on my eibach front bar.
Monday, December 06, 2010 8:24 PM
Philly D wrote:I have the same bushings as well...but on my eibach front bar.
That means you've had them out of the car, are they as hard as I thought they were when I fondled them when I was doing my dogbone?
Monday, December 06, 2010 10:42 PM
Wow, interesting responses. I'm going to have to look at mine when I pull them to install my eibach bar...I could have sworn they were the crappy rubber bushings, but now I'm thinking I may be wrong.
Monday, December 06, 2010 11:08 PM
I have moog end links on my car. they used to be blue.
thinking about upgrading the front sway to an addco bar anyways... one of the best suspension upgrades for the J body IMO
Monday, December 06, 2010 11:12 PM
wouldn't that big addco bar make it push even worse? Wouldnt higher front spring rates be a better solution to combat roll?
Tuesday, December 07, 2010 5:45 AM
mine are hard as a rock...was going to replace them with poly units...
Tuesday, December 07, 2010 6:04 AM
Cool. So these are the only bushings in the car that we replace with softer units?
Sunday, December 12, 2010 5:38 PM
Mine are hard white ones. But the ones from my 04 subframe I had when i got my motor was black. Weird.
Edited 1 time(s). Last edited Monday, December 13, 2010 10:29 AM
Sunday, December 12, 2010 6:50 PM
Leafy wrote:wouldn't that big addco bar make it push even worse? Wouldnt higher front spring rates be a better solution to combat roll?
I ran my car with Tein SSPs and an addco front bar(no rear sway) for an autox. That was the only time i had it push(understeer), but a few adjustments to the rear dampers fixed that.
Im now running a Progress rear sway bar and i love my suspension set-up. It makes for a very fun street car.
its an old concept. time for something new to take the reigns. - Z yaaaa
Sunday, December 12, 2010 6:56 PM
Actually Tinkles come to think of it, you're right. My car pushes at the limit when braking, BUT when on light throttle or no throttle the car is neutral bordering on push.
Monday, December 13, 2010 12:21 PM
Higher spring rates reduce body roll but at the cost of stiffer ride and loss of comfort.
Properly setup front and rear bar are the better alternative for neutral handling. It's neutral or nothing.
Misnblu.com
Newbie member since 1999
Thank you Dave and JBO!
Sunday, December 19, 2010 4:18 AM
They must have been replaced at some point.the ones on my 05 were black soft rubber. Now they are red and hard as rock.
Sunday, December 19, 2010 8:37 AM
The ones on my vert are hard as a rock....should I switch them for the poly ones I have laying around?
