Ok, I've read through a ton of discussions and stickies. I have a 2000 Cavalier sedan with FE0 stock suspension. Basically as you guys know I have body roll at stop lights. I've decided to go ahead and do some work and wanted some advice on what to get.
Right now I'm looking at KYB GR-2 struts, Eibach Pro springs/sway bar kit, front strut brace. How's that sound? Anything else? Thanks
Better struts are needed, those GR-2's are just stock replacement and wont like the drop too much.
Sponsored by:
Kronos Performance
Well how about Tikico HP's;
These are the springs and sway bars I was looking at;
And Strut brace;
Anyone know anything about these short shifters?
tokico hp blue struts are a good strut meant to handle a drop(and easily affordable, about the same price as stock struts and they're a well known name brand) . get yourself a decent set of springs, new strut mounts, front and rear sway bars, front and rear strut bars, a ttr subframe brace and that body roll your'e used to will be unheard of.
shifter looks like a b&m knock off, and since you cant get a b&m any more its your best bet besides the one PJ is working on.
Sponsored by:
Kronos Performance
any front strut bar will work fine. the gm one is the best imho. everything else looks good. i won't answer on the short shifter though as i don't own a manual and thus have never had to buy a shortshifter.
blucavvy wrote:tokico hp blue struts are a good strut meant to handle a drop(and easily affordable, about the same price as stock struts and they're a well known name brand) . get yourself a decent set of springs, new strut mounts, front and rear sway bars, front and rear strut bars, a ttr subframe brace and that body roll your'e used to will be unheard of.
I think you have the HP's(stock replacement) confused with D-Specs.
its an old concept. time for something new to take the reigns. - Z yaaaa
Tinkles wrote:blucavvy wrote:tokico hp blue struts are a good strut meant to handle a drop(and easily affordable, about the same price as stock struts and they're a well known name brand) . get yourself a decent set of springs, new strut mounts, front and rear sway bars, front and rear strut bars, a ttr subframe brace and that body roll your'e used to will be unheard of.
no sir. hp's are just non adjustable, they're fully capable of handling a 2" drop.
ya talk to a plus performance they should still be able to get the tokico hp kit. its struts with lowering springs for decent price! only bout an inch drop though. look up madjacks thread.
blucavvy wrote:Tinkles wrote:blucavvy wrote:tokico hp blue struts are a good strut meant to handle a drop(and easily affordable, about the same price as stock struts and they're a well known name brand) . get yourself a decent set of springs, new strut mounts, front and rear sway bars, front and rear strut bars, a ttr subframe brace and that body roll your'e used to will be unheard of.
truth. HPs can indeed handle a drop.
i like the setup you're looking at. decent choices all around. very good start.
hey guys i only have the pro eibach kit with new strut mounts and i've killed two set of shocks what are the smoothest ride struts that are non adjustable. all im really looking for is a low yet smooth ride
Modding my j since I found the org
x2. D-Specs with a different color and no adjustment.
yeah man i killed my my set in two months and then took it to my mechanich and he put on gabriel struts and killed those in two weeks before i found this web site now i have to try to get the gabriels back to the store to get my money back and try to deside whats the best soft street ride i have the eibach pro kit and need to find new struts for smooth daily driving.
^You're gonna want KYB AGX struts, quit getting OEM replacements
