Just double checking which strut mounts rk prostreets use . There 95-99 right ?
And to go with that has anyone ever found a set of camber plates that work with pro streets ?
Camber plates generally take the place of strut mounts so strut mounts aren't needed if you're going with the plates.
Check with OEM or overkillengineering.com for some front and rear mounts.
Good luck.
Misnblu.com
Newbie member since 1999
Thank you Dave and JBO!
