i tryed using a big sea clamp and wood blocks no luck idk if i hafta cut that sleave thing out for them to fit or what or maybe i can just use a vice had a hard time with it any tips
I used a vise alot of lube,Put bushing in vise and rocked the arm back and forth until it went in.
the steel sleeve needs to come out.
EvoFire wrote:the steel sleeve needs to come out.
This. An air chisel and a vise will work rather quickly
well i cut the sleeve with a battery sawsall in like 1 min then i got out alot of grease n greased the bushing then i got a 5/8s threaded rod and 3 square washers with square bolts pressed it in most of the way n it wouldnt seat so i took that off n beat on it with a ball peen hammer till it seated perfectly done lol pita though prolly took me an hr messing with the bushing to get it in i think
wow all i had to do was lube them up and push them in with a vice and rock them till thay seated
i love my arbor press...5 minutes had old out and new in...
Lots of lube, and rock the arms in a vise works just fine.
Ha! Seriously, what kind of lube, lithium, bearing grease?
Sig'less since '02!
Scorpio1 bishes... wrote:-MD- Enforcer wrote:Lots of lube, and rock the arms in a vise works just fine.
That's what she said.
I had to.
haha, funny sh*t.
Bench vice and some care to install and it's done.
It's that easy.
Good luck man.
Misnblu.com
Newbie member since 1999
Thank you Dave and JBO!
