star wheel broke? - Suspension and Brake Forum
star wheel broke?
Saturday, May 29, 2010 10:03 AM
i think my rear right star adjusment thing (Brake Drum Brake Adjusting Screw Assembly) is broke, do i need to take apart the whole system inorder to replace that one part?
~1996 Cavalier LS 2.4L (auto)
Re: star wheel broke?
Saturday, May 29, 2010 10:42 AM
youd have to do what it takes to remove the shoes usually. Remove the springs.
Sunday, May 30, 2010 6:35 PM
no just pry the shoes apart and the star wheel should fall out you should not have to remove the springs
Erik Packard
Sunday, May 30, 2010 7:54 PM
Ricozero wrote:no just pry the shoes apart and the star wheel should fall out you should not have to remove the springs
this. remove drum, spread shoes apart, replace star wheel. also, i would recommend replacing the shoes. if the star wheel broke, the shoes ate it. thus, needing replacement. if you replace the shoes, replace the hardware kit as well.
Sunday, May 30, 2010 9:01 PM
im looking at ordering the hardware kit also but i dont know which of these two i need. they are 2 types of sizes. which one do i pick?
~Combi Kit; Rear; 8-55/64 x 1-49/64" Brake; 1 Required
or
~Combi Kit; Rear; 7-7/8 x 1-49/64" Brake; 1 Required
Sunday, May 30, 2010 9:15 PM
Tuesday, June 01, 2010 7:06 AM
what car uses the 8-55/64" size? Z24?
Tuesday, June 01, 2010 7:07 AM
ok i ordered new hardware kit and shoes and the star wheel. i already had replaced the solenoid last week. hope these fixes the car was pulling to the right even after i had it aligned. i think the right wheel was braking and casuing it pull right. which is why i started to inspect the drum brake.
