Passenger side, large (rear) bushing has popped out of its place, any reason why it would do this? I am thinking of just taking the ca back out, pushing the bushing back into place and reinstalling it and calling it perhaps a fluke.
Has this happened to anyone else? (Prothane bushings btw).
If need be, I can post pics once I take some.
I purchased them in the GP and had the bushings installed..... I will take it out this week and snap some pics
(btw I had no idea the bushings had a up and a down, learn something new everyday!)
Isaak wrote:(btw I had no idea the bushings had a up and a down, learn something new everyday!)
oops. neither did i. i bet mine aren't installed correctly then.
my carDomain updated 3/2/10 Forged and Supercharged
It seems as though both are upside down, I do not have them out yet but as far as I can tell, the big part of the bushing is at the top... therefore the weight of the car is pushing down and the control arm is sliding down on the bushing. I will have them flipped and see what happens, I will take pics when I take them out.
i really dont see how installing it one way or the other would matter. the radius edge is only there for ease of installation and that part doesnt hold the bushing in place.
look at the bushing, i may have torn. a lot of times these bushings are so tight they actually tear upon installation. it sucks but this is why that radius edge is there.
![](http://i139.photobucket.com/albums/q289/fast97z24/zyasig5.jpg)
All I want... is a little of the good life
I will check, I didn't install them, I bought them in the GP with the bushings installed. It is odd how both are doing it, and the arms are installed correctly (L & R). I will take pics of the arms in the subframe and out to show what the bushing/arm is doing.
Let me know what you find out about it and i'll talk to John.
![](http://registry.gmenthusiast.com/images/tinkles/DSC00309.JPG)
^^^ i highly doubt that place would have let a set go torn. but i guess it is possible.
What place? John and I took care of the bushing installs.
Tinkles wrote:What place? John and I took care of the bushing installs.
I bought them through the ORG GP... I am not blaming anyone or saying someone should fix it for me at their cost, I just would like to know how this happened, and what I need to do to fix it so it does not happen again. I will more than likely remove them tonight and take pics of them... before I remove them though I will take pics of how the bushings sit now as when i remove them they will more than likely move around as I remove them from the subframe.
I should also point out these arms have seen maybe 10 miles of driving..... it has sat for awhile (winter) because it is my 3800 project car, but it made the metal on metal sound right away, as soon as I took it out on the road, it was the arm contacting the subframe (bottom of it).
Edited 2 time(s). Last edited Monday, April 26, 2010 2:30 PM
almost looks smashed... as if the steel sleeve wasnt installed.
is it in there?
steel sleeve? the sleeve thing in the middle of the bushing?
So....... what's the fix? New bushings? The bushings do look alright except for the one pic that does make it look chewed up.
The bushings looked ( and were ) brand new when the arms went it and I didn't have to force them in, so I am not sure why it looks chewed, I will attempt to take them out tonight.
Edited 1 time(s). Last edited Tuesday, April 27, 2010 2:39 PM
I might be wrong...But the pic with the control arm in the car "pic 2" it looks like a crack in the control arm...It may be dirt or something..
Just wear and tear on the arm
Sorry, but that's from pressing them wrong.
Let me show you what I mean and you'll see.
Notice how this looks like the picture above?
This was caused by not radiusing the edge of the control arm which has a square lip to it or edge.
If you don't radius it, this is what happens to the bushing and I'd believe this is what happened to your bushing.
It may have been installed this way in thinking that the bushing would hole.
It could have also been that even though they looked good after pressing them in, the damage was there with weakened sides of the bushings and the little wear they had revealed the fault of the install and failed.
Here's what I'm talking about damaged bushing waiting to fail if installed.
I've done alot of these control arm bushings and my pictures above are what happened when you don't pay attention to the edge of the opening and trying to press the bushing without radiusing the edge. And I greased the snott out of them, use a 12 ton shop press when I install so that wasn't an issue.
Good luck with the bushings and make sure that the edge is rounded slightly to help the bushing slip right in.
Misnblu.com
Newbie member since 1999
Thank you Dave and JBO! ![](/global/images/emoticons/cb.gif)
![](http://www.misnblu.com/misnblusig.jpg)
^^ my thoughts exactly. still dont get the 'squished' other side though....
