The struts are going bad in my 01 z24 so i would like to know a good brand of struts to go with that i am able to put a 2in lowering kit on. thanks
are those koni yellows? if so how much do those run?
Tokico HP's also can handle a 2'' drop.
Tinkles wrote:blue02zee24 wrote:Tokico HP's also cannot handle a 2'' drop.
Fixed.
yes, actually... they
can. they are the same damn thing as d-specs just without the adjustability. look it up, ask the company. dont follow the myths.
OP- yellows usually run around $600. and you have to make them work. if you are not mechanically inclined i advise buying either the tokico hp's or the dspecs as they are a completely bolt on and done affair.
We all need somebody to believe in something...
Really? All i have heard is that they are stock replacements, hmm. Oh well.
Tinkles wrote:Really? All i have heard is that they are stock replacements, hmm. Oh well.
yeah man, thats all i heard to. i had to learn the hard way as well from mr blue02zee up there ^^^ LOL
its no big deal though, were all students striving for information.
so which are the derect replacement that can handle a 2in drop? also for my 2in what brand should i go with. id like the easiest route possible
tokico d-specs/hp's can handle 2" and are both a direct bolt in and go deal.
easiest would be a set of eibach sportlines and one of those. personally, id choose d-specs as they are adjustable.
yes.
although you can find just the struts and then eibach springs a bit cheaper, not much but a little bit if you look around.
