hi!
i have a couple of questions regarding this swap.(yes!!i searched and red the sticky a million time)
but i got lost at some point(french canadian...)
i have acess to a 1993 chrysler concorde with the rear disc setup. for 75$ i can have everything i need to do this swap
here's my 1st question:
can i use: caliper bracket,dustshield,caliper & hardware from this vehicule(1993 chrysler concorde)
or do i absolutly need dodge neon parts??
and can someone give me parts number from Napa for every fitting i need for this to work
and if someone could give me the exact measurment so i could give them to the machine shop it would be a big help!(i cant find it)
thanks guys!!
!pıɐן ʇǝƃ oʇ pǝǝu noʎ sıɥʇ pɐǝɹ uɐɔ noʎ ɟı
-_-_-_-JCO EastSiderZ-_-_-_-
I belive everything your asking has been covered in the sticky, including a list of cars you can use the rear brakes from. All the measurments and parts needed are there. I had to go through 20 some odd pages to do my swap lol. I know it sucks but everything is there for you!
"Straight roads are for fast cars, turns are for fast drivers"-Colin McRae
ok ill try to read it again
(2) EAR-989534ERL - the hardline fitting adapter
(2) EAR-997634ERL - the 7/16" banjo fitting (you will use the stock banjo bolt on the caliper)
(2) EAR-63010126ERL - the 26" SS line (you can also try using the 24" line, but it might be a little tight for comfort)
Those are the fittings and lines I used for my swap. I am using everything from a 96 neon sport so the fittings may not be the same to attch the brake lines to the calipers. the concorde calipers.
You can use the rears from a concorde it appears. Here is the list with all the vehicles you can use.
2001 - 2006 PT CRUISER
2004 - 2006 SEBRING
1995 - 2005 NEON SPORT
2005 - 2006 STRATUS
Calipers:
CHRYSLER
1995 - 2000 CIRRUS
1994 - 1997 LHS
1993 - 1997 CONCORDE
1994 - 1996 NEW YORKER
1989 - 1995 LEBARON
1996 - 2000 SEBRING
DODGE
1989 - 1990 DAYTONA
1989 - 1990 SHADOW
1993 - 1997 INTREPID
1990 - 1995 SPIRIT
1995 - 1999 NEON
1995 - 2000 STRATUS
EAGLE
1993 - 1997 VISION
PLYMOUTH
1990 - 1995 ACCLAIM
1995 - 1999 NEON
1996 - 2000 BREEZE
1989 - 1990 SUNDANCE
For the machining of the bracket all I did was bring a old wheel bearing to the machine shop with me. They were able to make measurments of the bearing and drill the bracket for me.
thanks bro!!
do i really need to put that 2psi valve??(reading that how to can get confusing...)
Nope no valves needed mine work fine on the stock residuel pressure valves
