Does Ground control make a sleeve kit for the Tokico D-spec strut? I have contacted them a few times and never get a e-mail in return. If anyone could help I would appreciate it.
why wouldnt a regular GC kit fit ?
I thought that there are different sleeve diameters for the different struts. Isn't there different ones for yellows, stock struts........
i dont think so.. but dont take my word for it though /
holy sig, alittle too big
I believe its to do with the top hats of the coils...the konis have a differnt shaft diameter. Easiest way is to call and ask..
I think the d-spec is the same as the stock strut if I remember correctly.
ok well i think "stock" sleeve kit is out of the question because dude in "Ground Controls with Tokico Dspecs.." post had them on d specs and the front fits but the rear sleeve he had to hone them because they did not fit.
either koni or kyb. not shure
instagram: peru_stylez
i can't give you an answer, but i can confirm that there is different size sleeve inserts, i had stock strut ones, but than put them on koni's and had to buy the koni inserts cuz the stock ones were lose of the strut body...only $40 iirc for the diff. inserts.....the fronts are the same no matter what strut, its the rears that make a diff.
