over kill? lol im about to get two more compressors.. but only plan on using two at a time. 3rd one will be for spare and back up. but using 3 was a thought.
overkill for that size tank. only thing i can think of haveing 3 is the fact that the tank will fill FFFFFFFAAAAASSSSttt so lots of play time lol. just make sure ur tank pressure sensor works right to shut them down. post the setup when ur done
The only downside is the extra electrical loads, but depending on their size you should have that tank in one minute. Mine takes about 5 minutes with a Viair 380c.
Tinkles
![](http://registry.gmenthusiast.com/images/tinkles/Copy%20of%20DSC00426.JPG)
![](http://i20.photobucket.com/albums/b229/blink182170/disissofunny.gif)
2003 Cavalier 1SV
Bagged and Blown
I hate waiting. Most likely will only use two though.
Should have boughtmy Air Zenith man lol...filled my 5 gallon in less than a minutes, and the compressor head was cool to touch after running it HAAARRRDDDD
I'm using 2 compressors on my 2 5 gallons and there quick as he'll. Also have a third as a spare. Always nice to have have one cause u never know when ur gonna need it.
you guys talking about 0 psi fill or recovery time?
Recovery time for myself.
Tinkles
2003 Cavalier 1SV
Bagged and Blown
takes mine like ten minutes i think to go full rise.
ten minutes i ment from 0 psi... i thing my compressor is too good right now. guess ill see when i install the new ones
From 0-175psi with a single 5 gallon and the AZ compressor was a little under 4 minutes. 145-175 was just under a minute.
Drag it to death wrote:^^^^ bout the same here.
Only difference is the AZ's dont get hot
i got two azs and an edc on mine and it still aint enough from 0 to 175 is just over a minute 145-175 is 7 seconds lol
Twisted Cav(sdwndr2) wrote:Drag it to death wrote:^^^^ bout the same here.
Only difference is the AZ's dont get hot ![](/global/images/emoticons/cg.gif)
yeah u better not touch my compressors after I run them!!!
