I have rk sport ajdusting coilovers to go with my agxs.. one of the collars/perches w/e you call them is stuck and the bolt that losens it free in order to move up and down is stripped. drilling didn't help so am looking to buy this stuff new/used and replace that part.
look at
THIS whole coilover kit and i would still obviously use the rks springs with them.
will they work seeing as they have double adjusting sleeves????
Same here. No matter of fact hell no. You will be replacing more than those a day or two after installing. Drill and tap replace with bigger bolt or similar.
i drilled the sh*t out of it. how/what do i use to 'tap' and make sure the new screw works properly?
take it apart and take it to your local machine shop...tell them what you want done and pick it up in an hour..
it is easy to do.....but easy to @!#$ up
____________________________________
Primer Counts as Custom Paint Right?
BTW: This is my Sig.
