Suspension noice/squeak - Suspension and Brake Forum
Wednesday, April 15, 2009 2:14 PM
Over the past month i have noticed a noise coming from underneath the car, or so i assume. It happens everytime i get into the car, as the car lowers, and i believe it might be the suspension. It happens everytime i take off and the car shifts weight or when i go over a speed bump at low speeds. I hope someone has had this issue and could really tell me what it is. I really cant descrive the noise very well. I will attempt to take a video and post it here later this week.
Re: Suspension noice/squeak
Wednesday, April 15, 2009 2:19 PM
Sorry. I meant noise. lol. I've had a long day and I just saw the spell check at the bottom too. lol
Wednesday, April 15, 2009 2:30 PM
Should be the strut mounts, because mine is doing the same thing. But someone else drop in to give more insight into this please. Mine does it with faster compression and rebound of the suspension,
03 Sunfire - Sold.
Re: Suspension noise/squeak
Wednesday, April 15, 2009 2:38 PM
If it helps i have Koni Yellows on Eibach Sportlines
Wednesday, April 15, 2009 4:00 PM
I have Koni Yellows and RK coilovers. The front creaks with body lean and such, but the mounts are supposedly bad. I haven't replaced them yet.
You know about the solid mounts from OEM right? http://www.overkillengineeringmotorsports.com
Wednesday, April 15, 2009 4:52 PM
I'm inexperienced with car. I have no idea about the OEM mounts. This car was handed down from my friend. he moved out of the country and gave me the car. it has about 84k miles and it still runs great just problems like this noise, brakes and dash rattling all the time. so i should just replace the mounts and i should be fine? Any suggestions on good ones?
Wednesday, April 15, 2009 5:14 PM
I also know about the OEM mounts. All i have to say to the OP is that if you plan on keeping your car, I wouldn't even hesitate to spend the money on the OEM mounts, best designed mount for our cars period, and ill recommend these guys all day as they make high quality J-Body specific parts. I would get a set too but my car is hopefully getting sold this summer. Even if the mounts aren't to bad, i'd still get them, better handling, plus adjustability if you want it. www.overkillengineeringmotorsports.com
03 Sunfire - Sold.
