caster - Suspension and Brake Forum
caster
Friday, April 10, 2009 7:22 PM
I had a twisted control arm and i had to get my car on a fram machine to straighten it back out i also had to replace my upper moter mount and shim my rear end. the caster to the pasenger side was fixed and after awhile i needed to replace the pasenger side cv joint boot and had to replace my control to do so when i did pasenger side alighnment was 9 degrees out and camber was 2.53 and the caseter was 3.6 degrees off center and i measured it and the tire sits in the correct position in the fender. all input is very apreciated please help.
Re: caster
Friday, April 10, 2009 7:56 PM
......... so whats your question?
ECOtec DOHC
Re: caster
Friday, April 10, 2009 11:57 PM
what could be throwing my caster out so far?
Re: caster
Saturday, April 11, 2009 9:57 AM
What is spec? There is no caster adjustment on our cars. If it is out of spec something is bent.
Re: caster
Sunday, April 12, 2009 9:19 AM
Do you have any ideas of what is bent or could be bent?
Re: caster
Sunday, April 12, 2009 11:49 AM
caster is the angle of the spindle.
two possibilites, the top of the strut tower is to far back or the engine cradle/mounting points were pulled to far forward
i would have the frame shop check how it was pulled
you could change the caster but it would include bending/redrilling/moving the parts involved (spindle, strut, mounting locations)
Re: caster
Monday, April 13, 2009 7:12 AM
I hope it dont cost me much more to keep this car am already into it just under 3k just to fix it
Re: caster
Monday, April 13, 2009 5:52 PM
3.6 degrees positive or negative? Also, is it the same (or close) on both sides?
Re: caster
Monday, April 13, 2009 6:53 PM
its positive and the other side is just fine it just the passenger side of my car got messed up in a street race "why i dont do it anymore" and i got cliped at 108+ and slid into a few curbs and a dranige ditch.
Re: caster
Monday, April 13, 2009 6:56 PM
maybe the subframe got pushed somehow. subframes are suppose to move in an accident.
ECOtec DOHC
Re: caster
Monday, April 13, 2009 7:12 PM
teh subframe moving back would move the control arm back which would make it negative caster. in your case the subframe would have to have been pulled to far forward or teh strut tower moved back.
how are the control arm bushings?
extremely worn bushings will cause the control arm to relocate
Re: caster
Tuesday, April 14, 2009 7:38 AM
my control arm bushings are good i just replace them when i replaced the control arm, ball joint, cv joint boot, and the control arm bushings.
