WHEEL BEARING REMOVAL. - Suspension and Brake Forum
Tuesday, March 24, 2009 8:47 AM
This is my first attempt at changing them and after I removed that big bolt the bearing will not come off. What other bolts are there that I'm supposed to remove? Thanks for your help.
Re: WHEEL BEARING REMOVAL.
Tuesday, March 24, 2009 9:54 AM
the 3 torx bolts holding it on
____________________________________
Primer Counts as Custom Paint Right?
BTW: This is my Sig.
Tuesday, March 24, 2009 12:30 PM
remove the torx and give it some love from a BFH. then when you install the new one use antion the lip of the bearing that sits in the knuckle. This will make it much easier to remove in the future. and don't be a pussy when using brute strength to remove the original they can be quite a pita. Good luck.
Wednesday, March 25, 2009 5:59 AM
just dont have your face in front of it when you do it. it hurts...
