What is the proper sequence in bleeding all 4 pistons on the wilwood calipers? Does anyone know?
they should be done in the same order that a car would be.
Farthest from master to closest to master.
Do you have ABS still? Are you asking how to bleed each piston, cause it should only be 1 bleeder per caliper.
The wilwoods have a seperate bleeder for each piston. If I had to guess i'd say do the lower ones first
really??
in that case, yes. bleed from the bottom up.
and outside in.
so.....if only bleeding the fronts, it would be RF outer lower bleeder, then RF inner lower bleeder, then RF outer upper bleeder, then RF upper inner.
etc.
Edited 1 time(s). Last edited Friday, November 07, 2008 8:58 AM
