Has anyone put these on?
What is result in fit?
Here is my problem.
I want koni sports all around on my 98 z. Damn fronts do not come with housing(that i can find so far after a week of searching).
So i figure worse case scenario i put yellows on back and what on front? (any wise cav. experienced peeps please chime in.)
I do not do this as a hobby but rather cuz i gotta replace my stock set up as it is beyond shot, it slid me out on a bend and into a fence, no one was hurt but my car.
I dont care bout dings n scratches so it pissed me off a bit but more so cuz i lost control.
I drive as fast as i can always and it costs me but i cant help it, its the way i am.(workin on $1000 ticket from highway)
I need the best handling without getting too mody or part specific for this car as it is all i can afford for the next while.
Gonna go with h&r springs n 225/55/16 potenzas n was hoping KONI yellows but those lame f-ers f-ed up my front plans!
Any suggestions for alternatives or combos?
like h&r with sensatrac on front n koni on back? or whole other struts?
please help. this is driving me nuts with all the info i've had to absorb n i dont have the time to get all up to speed on all the tech! I just want the best combo and be done with it.
Oh, btw how do i get my car to go past 172(i think thats where it stops accelerating)kmh?(forgot name for devce, is it 'governor' that stops acceleration?)
Thanks in advance.
Guy that drives but does not tinker
you have 2 choices for the H&R springs, Koni Yellows which are inserts for the front, or Tokico D-Spec (
D-SPEC's not the the HP's or anything else they make, D-specs)
it doesnt have to be H&r springs...simply what is best strut/spring combo for MOST improved handling...I just want to buy it and bring it over to my guy n have it all thrown on and then start ripping around
Even if you use your stock springs, koni yellows will offer a vast improvement in ride quality and handling over stock struts. They are adjustable externally, so you can test drive a couple miles, and if you want it tighter/firmer, get out and give all four corners a twist and your good to go.
I currently have koni yellows and B&G springs, w/ the koni's set to full soft all around, and the ride quality is not jarring or bouncy; the cornering is improved greatly from stock.
If you want maximum cornering ability and don't care about ride, consider Tein SS or the newly released STD coilovers
I've done konis (I did Koni Sport Kit -- springs and struts in one box). You have to take your old front struts apart and drill out your rear strut mounts to deal with the bigger strut piston.
It's honestly not as scary as it sounds.
I used this how-to
http://www.j-body.org/forums/read.php?f=3&i=77664&t=77664&p=3
Sleeper style, they don't see it coming that way.
just by smacking on some struts and 225 tires does NOT make your car safe at high speeds.
The J-body has a speed limiter for a reason, and IMO it should not be as high as it is. So I dont think you need to even consider removing it.
But, the Koni's are a fine choice, as are D-specs. But sounds to me like a waste, cause you are just going to wreck it anyways. I have never even heard of a $1000 ticket on the highway, and I dont even want to know how you got it.
Do me a favor, and just park your car and take the bus.
Considering you just joined and it says your born in 1901.....I bet its another guy from another forum picking on j-bodies....
I've asked him to update his registry with proper info before posting again. Remember... this isn't an anonymous site.
oldskool wrote:Even if you use your stock springs, koni yellows will offer a vast improvement in ride quality and handling over stock struts. They are adjustable externally, so you can test drive a couple miles, and if you want it tighter/firmer, get out and give all four corners a twist and your good to go.
did u have to chop your front housing?
Cuz thats my problem, my mechanic is not willing to chop and pop the inserts in but i do want konis in the back...so what would be a good option in the front to match the koni yellow in the back with h&r springs?
my goal is to get the best handling possible for the simplest installation possible.
thanx
John Benham wrote:just by smacking on some struts and 225 tires does NOT make your car safe at high speeds.
Im not gonna wreck...u do realize its 'kph'...and the reason for the speed was very special and as murphy would have it there was a cop coasting between 2 rigs otherwise never would have got tik for going 50 over limit...in process of appealing it as it was 'under special circumstances'...do not underestimate my driving skills or any skills as you do not know who you are talking/typing too!
As for those who are not quick to judge, i would really like your input as it seems u guyz know your car and its best combos...i need to be kept glued to the road.
This is a free site. In America...right?
SO you have more than you need AND I am not upto some nefarious deed here so just relax and help me out or admit to bieng some sort of control nazi/dictator with a paranoid sensibiltiy and well proceed from there.
s s wrote:oldskool wrote:Even if you use your stock springs, koni yellows will offer a vast improvement in ride quality and handling over stock struts. They are adjustable externally, so you can test drive a couple miles, and if you want it tighter/firmer, get out and give all four corners a twist and your good to go.
thanx
Just go with tokico D-specs if you cannot find someone to cut up the stockers
BTW don't post up here with your intentions to make the car "speed worthy" for the highway and expect not to get your ass busted for it at least a little. If you're truely interested in speeding, don't forget to upgrade the brakes, aside from the stock struts, they are truely one of the most sucky OEM performing parts on our cars IMO
My suspension/braking set up for "high speed stability":
- koni yellows on stock springs adjusted for your tolerance on ride comfort
- addco front and rear sway bars
- overkill strut mounts (front and rear when they're available - good for ~1" lowering
- TTR k-brace
- front and rear strut tower braces of your choice
- SS braided brake lines
- hawk HPS pads on nicely resurfaced rotors or new aftermarket rotors of your choice
- BFG KDW-2 on stock 16's inflated to 32psi front 30 psi rear
This isn't going to make for the most effective cornering possible (for auto-x for example), but it will feel/be stable at highway speeds and maintain a reasonable comfort.
s s wrote:John Benham wrote:just by smacking on some struts and 225 tires does NOT make your car safe at high speeds.
Unless your reason for that speed was taking a dying relative to the hospital, there is no exuse for going 50 KMH over the speed limit. and even then, they should be in an ambulance, not your cavalier.
You come to the site, and in your first post ask how to over-ride the speed limiter. Granted you did have a valid suspension question in there, which I DID anwser in my post, but I also wanted to express my dislike for people that think there car is some type of supercar, and they are indestructable.
If you want to sit here and E-thug me, whatever. I am just saying people on this site dont look kindly onto those who want to modify thier car to drive unsafe on the streets.
Like this neon, at 100 MPH (about the speed you are asking to go over)
driving skillz or no, a car that is not designed for the speed you are going, is an unsafe situation you put yourself, your passengers, and everyone else on the road in danger. If you want to drive fast, go to a track.
K, John agreed.
speed is time travel
oldskool wrote:s s wrote:oldskool wrote:Even if you use your stock springs, koni yellows will offer a vast improvement in ride quality and handling over stock struts. They are adjustable externally, so you can test drive a couple miles, and if you want it tighter/firmer, get out and give all four corners a twist and your good to go.
thanx
- overkill strut mounts (front and rear when they're available - good for ~1" lowering )
- TTR k-brace
Did you do your back brakes?
And the '- overkill strut mounts (front and rear when they're available - good for ~1" lowering )' is new to me going to research right now, but did this allow for easier install of konis?
From what i can sum up so far its koni and d-specs.
Are the differences not to noticable or any? Or is it totally subjective?
d-specs come only in sets of 4 that i can find so far...had mind set on koni in back so i was hoping for a suitable slap on strut (that can handle h&rs) in front...I wish my mechanic would just do it or that i had tools cuz cinny's step by step was really good and I want to do it but money and location r a big factor right now.
Thank you though oldscool for your input! It means much.
thanx
To do koni yellows up front you do have to "chop" the front struts open. Did you even read the how-to I posted?
Plus, if your mechanic isn't willing to do a proper koni install...it's time to find a new mechanic. I did it myself with a hacksaw and power drill for the fronts. Needed a drill press for the rear strut mounts though. Any mechanics shop ought to have one available however.
Plus, I'm going to echo everybody else here on the forum. The cavalier is an econobox primarily. SLOW THE F DOWN BEFORE YOU KILL SOMEBODY ELSE DUMBASS!
HEY! Call me a dumbass again and...and...youll c punk....anyways yes i did read your post, thanx.
My mecahnic is a buddy who gives me a great deal so i keep it short and sweet and simple....AND CUZ this car is basically an over charged go-kart i keep it neet and UNDER CONTROL ...besides I already pay my price for speeding so I DO NOT NEED TO HEAR IT FROM ANYONE! GOT IT!!!
Ican drive anything, you should see me handle my sk8 or my snowboard, you would wish you were me; to put it modestly.
So stop grannieng me. Like u dont speed!
You ever ask yourself how old speed laws r? school zones and residential are ok but all else could stand to catch up with the times,
its kept this way to be a cash grab for the man, prey on motorists and let crime florish while chumps, i mean cops hand out tickets and help all that is wrong with our 'democray' continue (and by that i mean corporate extorsionists who dictate our laws, ie INSURANCE COMPANIES-why is it they always hold onto tickets LONGER than the actual driving ministry? to EXTORT US. why does my premium go up cuz of one traffic ticket even though I've NEVER used accident insurance and cost them nothing? AND NO IT DOES NOT MEAN I AM MORE LIKELY TO GET IN AN ACCIDENT OR CAUSE ONE...I'd love to see the stats or studies they have to prove such an inflamingly biast and discrimanatory practice!!!!---STRAIGHT UP JACKING US/ME---ALSO KNOWN AS LEGAL EXTORTION!! SO @!#$ YOU AND ANYONE ELSE TRYING TO TELL ME ABOUT DANGER AND SPEED! READ SOME PHYSICS BASICS AND U MIGHT REALIZE SPEED IS ACTUALLY SAFER THAN LETHARGY)
I have not caused any accidents in all my years driving and ALL those years I have been 'speeding'; its called skill and intelligence that i guess most lack so maybe that is why they need to b protected? i dont know, seems that way...if i have to explain it u obviously dont have it.
SO watch your mouth/mind cuz it says/types ignorant things. u dont know me. n i dont know you.
Speed is not dangerous, STUPIDITY IS.
thank you,
have a nice day
...oh and GET OUT OF MY WAY
-speed is time travel-
You're out there man...
You keep talking to people like this, and nobody will help you. It isn't a rule that we have to help newbs, and it certainly isn't a rule when that they want to be arrogant and ignorant that we have to put up with it.
Nobody help this dude. Seriously.
quick edit: I'm damn glad I don't live near you. If I saw the same @!#$ base model Cavalier running around a top speed everywhere everyday eventually I would take my much faster non Cavalier car and catch your ass, and then when you pulled over I'd beat your ass.
It's not @!#$ safe. End of story. Not for Mario Andretti to do it, and not for you - some @!#$ in a Cavalier.
Edited 2 time(s). Last edited Saturday, November 08, 2008 9:30 AM
s s wrote:HEY! Call me a dumbass again and...and...youll c punk....anyways yes i did read your post, thanx.
thank you,
have a nice day
E-thuggin' at is best (worst?)
Speeding is one thing (+5-10=whatever) -- driving like an idiot is something else entirely (+10 or more).
If you want to be taken even remotely seriously, learn how to spell and utilize a bit more structure.
Wish I were you? Come on. You think you can drive? Come play at the track. Hell, to make it fair you can use my car (AutoX is the drug of choice), that way there's a good apples to apples comparison. We'll see just how good you can drive. Just remember -- you break it, you bought it.
And once you get your feet wet with some real competition, get your head out of your ass and slow the hell down. And yes, speeding does increase the chances you will be involved in an accident. Period. By driving at excessive speeds you decrease the amount of time you have to react to things on the road, increase the amount of time and distance your car takes to stop, and when (not if) you hit something, you will hit it just that much harder. Use the head on top of your shoulders, not the one hanging from your pelvis.
Read up on physics? Physics says that speed is more dangerous. Mass * velocity = energy, energy=pain in a crash. Hmmm....
Speed=paying better attention? If you can't pay attention driving at a reasonable speed, you don't have any business being behind the wheel. Seriously.
From your attitude and communication skills, I'd say you've been driving for about a year? Maybe 2? Any more than that and I want you to pick my lottery numbers, because if you drive the way I think you drive (and describe yourself for that matter), you're the luckiest SOB I've ever heard about.
Ugh. My city and state are in my profile. If you care to take me up on my driving challenge offer, this is my region:
http://www.cscc-scca.org/
Pick an event and give me some notice. If you can be civil about it, I'll see you on the track. On the way to the track, I recommend you shove a 2x4 under your skinny pedal.
You can PM if you need better directions than what's on the CSCC website.
KFLO wrote:You're out there man...
You r obviously ignorant and base...just read your response turtle dove...and since u r so tuff i would b so scared of you 'beating' me; quit while ur ahed jed and that way the only thing red will just b ur neck. mental midget.
squisher00z24 wrote:s s wrote:HEY! Call me a dumbass again and...and...youll c punk....anyways yes i did read your post, thanx.
thank you,
have a nice day
Ugh. My city and state are in my profile. If you care to take me up on my driving challenge offer, this is my region: http://www.cscc-scca.org/
first its not a marked or professinol letter so whatevs, cides an monkey can use spell check n i know my ill-diction is still phonetically correct, c.
second the physics part junior is relativity, my reaction time since im moving quicker IS quicker...there are sooo many assumptions u r maken that it just shows you think more of yourself than is warranted...i am always driving to tolerances/allowances and there are many many factors....i see you b4 you see me, just try to comprehend the 'relativity' bit, u just might get it.
you who comment along these lines are dangerously pedantic!!!
SO where were we....oh yeah, it doesnt matter anymore since all the bickering has pretty much hi-jacked this thread...
BIG thanx to those who answered and some of those who answered but still scolded, I can understand where u r comin from but u r assuming the worst....i believe in mey point of view and am way aware of anything u think u might be 'introducing' to me so thanx for the concern but its not needed.
Gonna go with tein ss after all.
its nice to see so much conservative 'level-headedness'.
oh and that track offer is great...im gonna see where u at and if its possible, its a gentleman's offer and that is enticing....i would cover any damage for sure but there would not be any....ive only once slid of a bend covered in black ice AND because of my driving skill(so napolean d) i avoided potential nastiness....AND so many times cuz i pay too much attention i have saved others from dingers and controlled the flow/space/peace....its not me im worried about; its them/(maybe) u (but i dont know u, u just might b awsome!)....(classics)
oh just for @!#$s n giggles:
-> do u subscribe to the "wear a helmet" when riding your bike or in-line fruit bootin or brushin your teeth?
with all this safety around its gonna fuk up darwinian evolution, be brave, take a chance.
oh and squishy, im in toronto n ur in indiana so thats a big no can do, gotta pay off my highway robbery tickets before i can take a trip anywhere
oh and just to be the consumate perpetual rebel, I run reds and stops and speed more when i get a bs ticket, u know cost averaging!!! since im payin might as well REALLY get my moneys worth, its like a membership!
so damned b any who try to tell a just man what to do
there is no enemy only the illusion of one so that you may not see the real one within(amongst u).
(too deep? oh well im goin thru heavy ish n some of u remind why it is sooooooooooooooooooooooooooooo hard to institute real change, cut ur strings puppets)
one day u will get it or u wont but u will get knocked the fuk back.
man if only....u will c....its amazing....then u can go 'hey that guy used to drive a cav(2.4 BTW)- i like to call it Zed- and wow he issss good
OH and super BTW- I DO NOT RACE ON STREETS.
i could care less if your @!#$y car beats my @!#$y car and yet u act like U beat me-wow super foot pressing power-yah know, lame; get out and run or challenge me to something where its just you n me -mono i mono, then its a personal victory.
What is the riddle of steel?
oh god you're from Toronto?...fukcs sakes, now you're making the rest of the Cnadian's look bad
