D-Specs/Sportlines vs. The World - Suspension and Brake Forum
Thursday, October 09, 2008 11:11 PM
as you can guess, I'm runnin Tokico D-Specs with the Eibach Sportlines.. I love the set-up, the way it rides and all.. but I wanna get lower, in 2 aspects: for one, I wanna fill the wheel-well gap. I know this can be accomplished with runnin bigger wheels and tires (I'm already on 18" Rotas, and new wheels are NOT in the budget), but that would add strain to the other field of lowering: ground clearance. my dilemma is that I just put a Type J kit on my car, and well, I was expecting to be a lil closer to Earth than it is.. so my first thought was to replace the springs with a set that has a greater drop, but still be able to keep the D-Specs.. any suggestions?
R.I.P. JessE Gerard 7.11.87 - 1.25.08
The Radiation Nation Facebook Twitter Twisted Metal Alliance
Re: D-Specs/Sportlines vs. The World
Thursday, October 09, 2008 11:48 PM
coilovers?
Friday, October 10, 2008 3:14 AM
Kardain wrote:coilovers?
yes you are going to want coilovers. sportlines are one of the lowest springs so you wont find anything lower. if you need to go lower then you need coilovers. dspecs will work fine with ground controls
Friday, October 10, 2008 1:27 PM
I knew coilovers were an option, but I wasnt sure if there were any other springs on the market that offer a lower drop before resorting to coilovers... we're talking about the threaded sleeve-overs, correct?
Friday, October 10, 2008 1:32 PM
all coilovers have a threaded sleeve. you have a coil spring and a thread sleeve with an adjustable spring perch so to say.
Friday, October 10, 2008 11:39 PM
right, the threaded sleeve with the 2 adjustable nuts that spin around the tower.... usually when I think of coilovers, I'm thinkin the pre-assembled kits like the TEIN SS's or the Basic Damper kit. I'm not familiar with the kits you put together, where you're buying your own shocks/struts, then the sleeves and springs separately and put it all together... I've read about them on these forums, but havent actually dealt with them in person
Saturday, October 11, 2008 10:05 PM
would you need to cut off the d-spec spring perches to get the CG's to work?
In the end, we're all just chalk lines on the concrete.. drawn only to be washed away.
Sunday, October 12, 2008 5:43 PM
i think but dont quote me on this but road magnet's springs are lower in the front then sportlines but the same drop in the back, i think lol...
http://corpsemangler.fortunecity.com
Sunday, October 12, 2008 7:37 PM
^^^ you sure? IIRC the RM's are less of a drop in the rear and equal to sportlines in the front. could be wrong though.
Sunday, October 12, 2008 10:48 PM
I've never heard of Road Magnet.. or IIRC for that matter
Monday, October 13, 2008 3:20 AM
cOrpsemangler wrote:i think but dont quote me on this but road magnet's springs are lower in the front then sportlines but the same drop in the back, i think lol...
its going to be about the same. its not that much different. why waste money on springs when your not going to be happy with the drop? use that money and just buy ground control coilovers
Monday, October 13, 2008 7:35 AM
IIRC = if i recall or if i remember correctly.
Monday, October 13, 2008 8:47 AM
I think the result the op is going for, he needs to get the coil overs.
or air.
Monday, October 13, 2008 8:29 PM
do the perches or anything have to be modded to accept the GCs?
