Yup you boys were right I am a complete moron. I lowered the car w/ a 2in skunk 2 coils and generic koni struts. I tightened up the control arm bolts but apparently not exactly to the right torque specs. I went to torque them down aft backing them off. I started w/ the front 90ft lbs and rear 125ft lbs. I didn't even make it past the front bolt when I heard snap, not click from the wrench. (side Note Craftsman torque wrench really sucks!) the front bolt snapped.  I was able to remove it and continue to screw the bolt out threw the back. Thank god for GM they make the most idiot mechanic friendly car there is. I was able to swap the snapped bolt for another one that was in the brace just in front of the passenger side control arm that I was working on. But here comes my next dilemma. This I need advice on. I noticed that the front hole for the front control arm in the engine cradle became a bit larger in diameter due to my slacked bolt and the arm jostling. So for now just to get me to and from I made a shim. I know the other side will have the same issue. What would you guys suggest?  I want to install a sway bar any way so do I A: buy a new cradle from gm parts direct, they I think go for $3-$400.00 and throw in fresh hardware or B: buy a junkyard special, Or C: just make some quality shims and go at it as is. I like the car so spending the money on a new/ used cradle is worth it to me, but would the shims be a complete waste of time? Any help would be appreciated. I cant thank you guys enough for the help you have already given. sincerely thanks to all very, very much..
Pics of the damage?  Get some opinions from people upon viewing some images and go from there...
14.330 @ 96.37mph
