does this sound right?? - Suspension and Brake Forum
Thursday, June 12, 2008 12:35 PM
does this sound "correct" to anyone? I was told but a service tech "turn the key to the on position and bleed the brakes so that way it will reset the valve"...? sound right?
BTW only 2 of my brake will bleed the right rear and the front left
Re: does this sound right??
Thursday, June 12, 2008 11:07 PM
thats half right in my manual it says to start the car and once the abs light blinks then turns off turn off the car and the piston in the abs will be at the top so you can bleed the system.
Monday, June 16, 2008 6:46 AM
are you trying to do an ABS bleed, without the use of a scanner??
I think Hardcore's description sounds more complete, but you may have to repeat several times.
