Just picked up some camber plates - Suspension and Brake Forum
Wednesday, April 30, 2008 6:18 PM
Just stumbled across these on ebay the other day and had a bit of cash on me so I figured why the hell not. Should be on the car this weekend or next week. They look like pretty good quality. Excuse the crappy pics.
Go Go OG Traction!!
Re: Just picked up some camber plates
Wednesday, April 30, 2008 6:27 PM
mcmoney's???
would they actually lower the car more, or increase it?
Rollin' on question marks since 07.
Wednesday, April 30, 2008 6:35 PM
hi
Wednesday, April 30, 2008 6:37 PM
Well, these are not as thick as stock mounts, so that will allow the car to sit lower without losing any travel. However, I may need to make something for Tein springs to sit on. I might need to get some top hats for the springs. I will play around with them this weekend and come up with something.
Oh and I dont think they are McMoney's, unless he has a store on ebay.
Edited 1 time(s). Last edited Wednesday, April 30, 2008 6:38 PM
Go Go OG Traction!!
Wednesday, April 30, 2008 6:56 PM
so there's more on there??
wha exactly do these help anyway?
Wednesday, April 30, 2008 7:04 PM
He makes these for many cars, but I dont see J-body ones anymore. Probably gotta wait for him to make more.
With these, you can adjust the camber on the fly. But more importantly, it gets rid of all that squishy rubber in the mount and makes the suspension more precise. Though they ride alot more harsh.
Go Go OG Traction!!
Wednesday, April 30, 2008 8:32 PM
I want some!!!
Thursday, May 01, 2008 4:45 AM
They're listed on ebay still.
About $200 shipped
Hopefully they work out for ya.
-M
Thursday, May 01, 2008 6:24 AM
is that a bearing in the center?? if not how does that work when you turn the wheel?
Thursday, May 01, 2008 6:31 AM
yes. it works just like a regular mount, however your able to adjust the camber right there on the mount and since its solid you dont get squeeking noises and it wont go back like the @!#$ty stock mounts.
Thursday, May 01, 2008 6:33 AM
my tein ss's have camber plates already. hehe. let us know how that turns out.
_______________________________________________________________________
my carDomain updated 3/6/07 Boosted at B-day!
Thursday, May 01, 2008 6:46 PM
well, I started dinking with them today at work. I am going to have to machine a top hate for the TEIN springs to allow them to sit on the bearings. Shouldn't be too bad. Also, the spherical bearing ID is 18mm, so I am going to design the hat to fit inside the bearing hole. I know I am not explaining this very well, but I will get the CAD drawings done I will post them up here to explain it. It might take a while to get these on, as I have been rather busy at work, but I will let everyone know the progress.
By the way, anyone that has ground control kits, these may be a bolt on affair for you. I would have to check what the bearing looks like on them to be sure though.
Go Go OG Traction!!
Friday, May 02, 2008 4:41 AM
t2 wrote:hi
Friday, May 02, 2008 8:35 AM
No caster adjustment in these though I am assuming.
Tuesday, August 05, 2008 3:45 PM
Nick,
Have you made any progress with those plates??
Jason
99 Z24 Supercharged
157hp/171tq - NA
190hp/170tq @ 6psi
LD9 for Life
Tuesday, August 05, 2008 6:19 PM
Anyone know the seller's ID?
11 speaker JL Audio stereo setup for sale:
http://www.j-body.org/classifieds/audio/52021/
Tuesday, August 05, 2008 7:28 PM
I'm curious to. I need some LOL
Tuesday, August 05, 2008 7:35 PM
John Benham wrote:No caster adjustment in these though I am assuming.
Did you see the pics?
Wednesday, August 06, 2008 5:20 AM
I only see camber adjustment, no caster....which is why I asked. How do you adjust caster with them exactly?
Wednesday, August 06, 2008 1:25 PM
OHV notec wrote:Anyone know the seller's ID?
101propose
http://www.mookeeh.com/
These plates only have camber adjustment, no caster. The only way I can think of to get caster adjustment is to slot the mounting plate itself.
Ground Control sells a set of universal camber/caster plates
Universal Ground Control plate
Jason
99 Z24 Supercharged
157hp/171tq - NA
190hp/170tq @ 6psi
LD9 for Life
Wednesday, August 06, 2008 1:45 PM
no cav plates......
Wednesday, August 06, 2008 7:35 PM
Just don't do what I do, and run negative camber for front wheel clearance. lol. Tires don't last long a -3. lol
Wednesday, August 06, 2008 8:40 PM
The GC universals are the best bang for the buck out there. You can even tell them your upper mount bolt pattern, and they'll drill it for you. I made a post a while back with all the dimensions in it. You end up with universal fit plates that are direct fit.
Thursday, August 07, 2008 9:35 AM
Toaster (stenger) wrote:Just don't do what I do, and run negative camber for front wheel clearance. lol. Tires don't last long a -3. lol
ouch.....
James Cahill wrote:The GC universals are the best bang for the buck out there. You can even tell them your upper mount bolt pattern, and they'll drill it for you. I made a post a while back with all the dimensions in it. You end up with universal fit plates that are direct fit.
that does sound like the best bang for the buck.....
Thursday, August 07, 2008 10:01 AM
Those are not Mcmoneys'.
