installing coilovers - Suspension and Brake Forum
Monday, March 31, 2008 4:05 PM
can someone help me out on how to install my coil overs?
Re: installing coilovers
Monday, March 31, 2008 4:35 PM
check out bradiscool.com and go to the garage section and click on the lowering spring install. its pretty much the same exact thing except your putting coilovers on.
Monday, March 31, 2008 4:47 PM
sites not working
Monday, March 31, 2008 4:59 PM
What are you having an issue with? They should come with directions, but basically, remove stock springs, modify perches (if required), install sleeves, install springs, install upper perches, put on car.
Monday, March 31, 2008 5:11 PM
i'm a noob with suspensions, so i don't want to screw it up?
Monday, March 31, 2008 5:21 PM
Tuesday, April 01, 2008 11:18 AM
What sort of coilovers are you installing? If you've got cheap generic crap then there are no instructions because there is no proper way to install them. If you've got something proper, they should have instructions though the members here will be happy to give pointers or answer questions if you've got any.
Tuesday, April 01, 2008 2:21 PM
i got a set of APC coilovers???
Tuesday, April 01, 2008 2:36 PM
Tuesday, April 01, 2008 3:11 PM
really? how come......?
Tuesday, April 01, 2008 6:04 PM
because it's apc.
Wednesday, April 02, 2008 5:12 AM
Yeah, sorry about your luck man, but you didn't get anything you should be putting on your car.
I thought APC went out of business. Is that not the case?
Do some research and you'll understand the problems.
