Do I need air tools to install my Sportlines? - Suspension and Brake Forum
Wednesday, March 26, 2008 11:10 PM
Are they a must, or do they just make it easier?
Re: Do I need air tools to install my Sportlines?
Wednesday, March 26, 2008 11:23 PM
air tools make everything easier
Thursday, March 27, 2008 12:42 AM
Just make it easier. Which is to say, may save you some scrapes, bruises, and psychological damage. But I feel your pain ... I don't have air tools either. Definitely worth getting once you can afford them though .... you'll save money in the long run with all the things you can do with them.
Thursday, March 27, 2008 2:13 AM
not needed at all. its handy but its not a requirement
Thursday, March 27, 2008 5:43 AM
the only thing thats a real pain is getting the nut on top of the strut tight since the strut will spin. do a search beacause i know a few people had suggestions on how to do it w/o air
Thursday, March 27, 2008 7:56 AM
I use a powerful electric impact wrench for those.
Thursday, March 27, 2008 1:16 PM
i did my drop without any air tools, it wasnt that bad
hop on in i've got a J
Thursday, March 27, 2008 1:40 PM
whiteboyz24 wrote:the only thing thats a real pain is getting the nut on top of the strut tight since the strut will spin. do a search beacause i know a few people had suggestions on how to do it w/o air
if your talking about getting the bolts on the piston rods tight without the strut spinning, i used a gear wrench to tighten and a crescent wrench to hold the top of the piston rod from spinning. for the rears anyway. the fronts just tightened no problem.
Edited 1 time(s). Last edited Thursday, March 27, 2008 1:41 PM
12.33 @ 111.67 mph [Oct 2009]
327.6 WHP 333.6 WTQ [10.1 AFR]
Thursday, March 27, 2008 4:40 PM
i did my drop without air tools too...
for the bolts on the piston rod, loosen them before you jack the car up. (loosen, do NOT completely remove)
put the weight of the car back on them to tighten them back up.
it should keep the strut shaft from spinning.
Thursday, March 27, 2008 10:05 PM
strat81 wrote:i did my drop without air tools too...
my stock rears were so rusted i couldnt get the bolt off, a buddy had to use one of them air tools with a circular blade on it to cut the nut in 4ths to get it off lol.
Friday, March 28, 2008 10:06 AM
they do make it nice and qwik, but no they're not needed.
