AIR RIDE HELP!! - Suspension and Brake Forum
AIR RIDE HELP!!
Tuesday, March 11, 2008 10:28 AM
ok so i got air ride the other week and just installed it. i have several questions that hopefully you guys< WITH air ride or HAD air ride, can help.
*note. i already have them installed so ive been riding on them for 2 days now.
whats a good setting for the dampers to be on? mines really bouncy and i havent adjusted it
do you get any kinda of uneven tire wear from the bags?
can i get an alignment?
whats the most psi i can fill the bags with? (most but safest amount)
for some reason i was thinking 150 but it doesnt seem high at all in the back when its at about 130.
thanks to anybody who can help!!!!.
I NEED a 97-99 LD9 engine harness for an auto.PM if u hav info.!!
Re: AIR RIDE HELP!!
Tuesday, March 11, 2008 10:38 AM
1) settings is up to you. what psi do you ride at? i use to ride at 45 in the front and around 35-40 in the rear. i forget what i had my struts set to.
2) no i went and got an alignment
3) yes however it will not be perfect after you hit the switches again. set your cars height to the height you drive around at normally then get it aligned. thats as good as it will get but you wont have any tread wear
4) you wont notice anything different say over 80-90psi. you can fill them to probably 150 but honestly, the height wont change really once you pass say 90psi
Re: AIR RIDE HELP!!
Tuesday, March 11, 2008 6:30 PM
he answered everything correctly/perfectly.
only thing i will chime in on is you shouldnt really ever have to go above like 80psi in the bags. as for 80 being the highest the car will really go and it ride likes crap. and for as much as they can handle easystreet says 120 i think but i had them up to 155-160 before and didnt blow nor should they
Re: AIR RIDE HELP!!
Tuesday, March 11, 2008 8:20 PM
great. thanks alot fellas. i appreciate the help. i will post pix this weekend when i can
Re: AIR RIDE HELP!!
Wednesday, March 12, 2008 10:16 AM
oyea i forgot to ask yall. but what did yall do to the front inner fender liner? did yall take the top one out so it doesnt hit the rim or did yall leave it alone?
Re: AIR RIDE HELP!!
Wednesday, March 12, 2008 10:19 AM
i had mine in and didnt have a problem
Re: AIR RIDE HELP!!
Wednesday, March 12, 2008 1:48 PM
i took mine out and the front one i had to cut up just a lil so i didnt rub.
Re: AIR RIDE HELP!!
Wednesday, March 12, 2008 7:14 PM
thanks again fellas. yall have been a big help
