I am looking to put on SS lines on my front brakes. I'm trying to do this as cheaply as possible and not buy a pre-made kit. Trying to make a universal SS line work. Does anyone know what size the banjo fitting is on the front rubber line going to the caliper, as well as the thread size on the other end of the rubber line?
1999 Grand AM SE (Beater Car)
1997 GMC Sierra
2007 Honda CBR 600RR
2005 Honda TRX450R
Use 14" lines. Banjo size is 10mm and other side is M10x1.0 bubble flare
Damn, that was quick! Thank you! Would you happen to know the thread size for the bleeder screws on the calipers? I want to try these
speed bleeders I found on Summit.
1997 GMC Sierra
2005 Honda TRX450R
input your car into the summit search options and it'll tell you which ones.
and if you search either the neon or nwf stickies (i think its the neon one) i listed the front part numbers for earl's from summit.
The front part numbers for the SS lines and adapters? And is bubble flare the same as inverted flare? I put my car info into Summit but it didnt list anything for brake bleeders.
1997 GMC Sierra
2005 Honda TRX450R
click your speed bleeder link, and put chevrolet cavalier under make and model and it will work.
and no, bubble flare is not inverted flare, they are completely opposite.
So does this look like what I need?
Summit Part Numbers:
EAR-63010214ERL (brake line)
EAR-989534ERL (adapter)
1997 GMC Sierra
2005 Honda TRX450R
that works, except notice that the lines are not in stock. iirc, summit normally doesn't stock those, and will only continue to backorder it unless you call them and tell them to drop ship it. you might be better off getting -3 to -3 lines and getting the banjos separate. thats how i've done all my lines.
Damn, I didn't notice that. Thanks for the heads up.
1997 GMC Sierra
2005 Honda TRX450R
Which one of these should I use?
EAR-997631ERL or EAR-9976031ERL
The only difference is one is round and the other is square, and of course the huge price difference. I know the stockers are square...does it matter?
1997 GMC Sierra
2005 Honda TRX450R
round works fine.
