Problem after installing skunk2 springs - Suspension and Brake Forum
Monday, December 17, 2007 1:20 AM
Once I installed them the driver side is sitting lower than passenger side.
any ideas why this could be?
Re: Problem after installing skunk2 springs
Monday, December 17, 2007 3:37 AM
are you on level ground? is one of the springs turned up side down?
Monday, December 17, 2007 6:07 AM
StrippedCav98 (Now Quotable) wrote:are you on level ground? is one of the springs turned up side down?
or is one not seated correctly?
Monday, December 17, 2007 9:11 AM
a majority of jbodies will have the front passenger side about 1/4-1/2" higher than the driver side. nobody to this day has been able to figure out why, but there are theories based on engine/tranny center of gravity, the battery is on the driver side, and normally the one person in the car (the driver) is also on that side.
Monday, December 17, 2007 9:20 AM
^^ i always wondered why I would see posts like this alot. lucky for me my D-specs and goldlines never did that when i had them.
Tuesday, December 18, 2007 5:33 AM
I was on level ground, I will check the springs to make sure they are seated and its way more than a half inch off.
I only put the springs on the front so far could that be the problem?
or could the springs need to be on a certin side?
Tuesday, December 18, 2007 6:38 AM
did you use the same springs for the fronts?
