Does anyone have any do's and don't about removing the front subframe ? I'm going to pull mine to beef up the RH A-Frame / Engine support for my 3800SC engine swap in my '96 Sunfire. Before I drop it out, do I need to mark anything or know where to look for that inconspicuous bolt that's always hidden until the damage is done ?
I'm going to replace the sway bar bushings and control arm bushings also while it is out.
John,
That's a REALLY NICE FRAME !!! Well thought out. Thank You for the ideas !!!
My frame is 2" square tubing 1/4" thick. Is that over kill ?
Also, do I need to mark anything when I pull the frame out, or will it go back into the original place when I put it back in ?
Thanks Again John...
Dont forget the steering rack bolts!!
Where do you get the Prothane (Poly-urathane) Bushings and sleeves at for the Engine Mount Brackets ?
That Power Steering Cooler tie down was a sneaky-little thing. Almost got me in trouble. It will be the one thing I will probably forget to put back on when I bolt the frame up. LOL...
